Aftermarket Radio Question 993 with hifi
#61
here is plug c. you are interested in the yellow portion that has all the signals to control and drive the Nokia amp
![](https://i482.photobucket.com/albums/rr186/e9stibi/post-72724-0-41936900-1317914091_thumb.jpg)
you need this adaptor!
www.discountcarstereo.com/ARH-ISO.html
I just checked the Kenwood radio spec and you have RCA outputs to drive 3 2-Chanel amps. Than it should be plug and play and you just hook up the 4 channels of the Nokia amp via the adapter.
Features are 4 x60 watts 4 ohms.
In the first image the back of the radio.
In the second image the Blaukpunkt connectors. It was connected to connector III and connector I, so it has amplifier (I didn't know).
Is an adapter like the one in the third image okay? https://www.discountcarstereo.com/arh-rca.html
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/300x300/0c45cb0c_e822_4071_824c_8cc663173c05_cr0_0_300_300_pt0_sx300_v1__a8615beb7c8301d266b9322ab65b2368a9f70cd0.jpg)
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/744x1051/blaupunkt_bremen_rcm43_7642898310_sch_pdf_2_d391bbde3618112179362bb13732bcdc74086567.png)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/289x234/arh_rca4_m_5102a2b1e44753db624c53bf72d74e97a90f26fb.jpg)
#62
The original blaupunkt car stereo no longer works. It was connected with connectors III and I, so it should have the separate amplifier.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/744x1051/blaupunkt_bremen_rcm43_7642898310_sch_pdf_2_32e081d9e0823341b43347c4a3db1bb0b8c29789.png)
I bought a car stereo with only one ISO connector and four RCA outputs (4 X 60 WATT 4OHM).
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/300x300/0c45cb0c_e822_4071_824c_8cc663173c05_cr0_0_300_300_pt0_sx300_v1__162374baef5dc031315591118c51ed7093dfdc6b.jpg)
Is an adapter like the one in the picture okay to use the old amplifier? (I don't care about the quality).
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/289x234/arh_rca4_m_f922e0e4dd8abdd3017bedd0ce5121fae9bf4ecc.jpg)
Thanks in advance
#63
Thanks in advance
