camber plate question
Happy New Year RLers,
I'm currently installing RS uprights and tie rods and am considering going ahead and doing camber plates and rear monoball shock mounts while I have everything torn apart. What affect would this have on harshness/noise? I don't have any experience with monoball components but know that they're definitely not recommended for suspension bushings on street cars.
Be sure to get some that are compatible w/ the shocks/spring it's not always just plug and play.
There are even sealed versions available ala the factory RS parts
I have the rennline camber plates and rear monoball mounts. Nice components. Given everything else I have done to the suspension I cannot really comment on the harshness added by just those. The car is stiff, you notice every bump and road imperfection but I still drive some on the streets and it does not bother me that much.
I have the Rennline rears w/ Bilstein Cup shocks on mine, they are very nice and come w/ the factory seals
![](http://forums.pelicanparts.com/uploads20/6_6_12_+0031340925804.jpg)
![](http://forums.pelicanparts.com/uploads20/6_6_12_+0011340925838.jpg)
![](http://forums.pelicanparts.com/uploads21/6_26_12__+0061344540159.jpg)
On the front I use Mode, which are no longer available(I think), no seal on these
![](http://forums.pelicanparts.com/uploads20/6_26_12__+0081340925872.jpg)
![](http://forums.pelicanparts.com/uploads21/6_28_12__+0011344540038.jpg)
I'm sure that the Rennline fronts are fine but I have had issues w/ the transverse sliding camber plates and prefer not to use them
I run the JIC's with camber plates/monoballs on my car. I like it and wouldn't think twice of installing them again.
You might take some points for them if you AX, so just one thing to consider.
