Outdoor car covers?
Hi,
I've heard good and bad things about using outdoor car covers. I live in a very wet area close to a river, which makes mist and low fog common, and have no access to a garage, my car get's driven a lot less than it used to as I walk to work, but I do use the car a couple of times a week all year round.
My question is do you think it would it be a good idea to cover it to keep the rain out or not?
Thanks.
Thanks.
I go back and forth with car covers as I park my daily driver outside. They block the UV, they keep the leaves, sticks, and bird poop off the car - those are the pros. The cons are that they are a pain to deal with if wet and dirty and they could put fine scratches on your car.
I use one if I won't be using the car for a few days or longer. Otherwise, leave it off.
I wouldn't use a cover if you're driving the car a couple times a week...probably makes sense if you leave it parked for 2-3 weeks at a time, but they're really a PITA to keep clean -- a two-man job to cover/uncover without it dragging on the ground. Plus you really shouldn't put a cover on a dirty car -- as mentioned above, it'll put fine scratches in the paint. So unless you're going to wash the car after every use, sounds like more trouble than it's worth.
When removing the cover I roll/fold it from the front to the top (so the front half of the cover is sitting over the sun roof). Ditto for the back half. I then roll the cover into a "jelly roll" starting at the passenger side. Putting the cover on is the reverse of this process. One person job and the cover doesn't touch the ground. Also, I have the Porsche cover that has four tie loops so that I can secure it side to side and front to back. We recently had some 50-60 mph winds and the cover did fine.
