993 Forum 1995-1998
Transmission fluid for '95 993...
Old 12-28-2012, 02:16 PM
coreseller
coreseller's Avatar
Originally Posted by Chuck W.
I did the turbo when it had around 41K miles on it using Mobil 1 Delvac. By the look of the fluid, I am guessing that it had never been done. This is an easy DIY. Also, a cheap tool that makes it so much easier is a Multi-Use Transfer Pump from Harbor Freight. Is $8.00 and worth every penny. I just did my daughter's BMW 328I and without the pump it would have been next to imposable.
LOL!!!! Coincidentally I changed out the 993 LSD equipped trans fluid with Delvac (bought 4 qts at a truck stop) a couple of months back, stumbled across this exact pump sitting new in the package in one of the lower tool drawers. I must have bought it at Harbor Freight a year or two back thinking I may need it someday, worked great as long as you hold the hoses in while pumping.
Old 02-01-2013, 10:28 AM
KNS
KNS's Avatar
So... where to buy Mobil 1 Delvac GL-5? No, not for the 84...
Where are you guys finding this stuff?
Old 02-01-2013, 11:13 AM
PAULUNM
PAULUNM's Avatar
You can buy it online- but an easier option is to go to a truck stop with a service station- Most T/A truck stops carry it- I even found it in liter bottles.
Old 02-01-2013, 01:13 PM
e9stibi
e9stibi's Avatar
get it at luftenik. Great service and great price.
Old 02-01-2013, 02:59 PM
NC TRACKRAT
NC TRACKRAT's Avatar
Or check with your local W.W. Grainger industrial supply.
Old 02-01-2013, 03:17 PM
hkspwrsche
hkspwrsche's Avatar
Truck stops or you can check the mobil site also. They will show which vendors carry heavy duty. For example a case of it can be found at the Carter machine here also. With a slight discount(just ask) it's cheaper and you can split it with someone.
Old 02-01-2013, 09:27 PM
Ed Hughes
Ed Hughes's Avatar
I picked up 4 qts at a very small Autozone today-they had plenty @ $10.99 per.
Old 02-01-2013, 11:57 PM
993_TJC
993_TJC's Avatar
I just got two gallons from Luftinic for$100.00 shipped. Tranny takes 3.7 gallons and the front diff takes about a quart.
May change it this weekend and will post pics.
Old 02-02-2013, 12:05 AM
hkspwrsche
hkspwrsche's Avatar
Good point some regular stores have it. The locator on mobiles site will help.
Old 02-02-2013, 12:06 AM
TheOtherEric
TheOtherEric's Avatar
Lol at the Harbor Freight hand pump. Last time I was there, I saw that sitting on the shelf and I said "I have no idea why, but I'm buying this thing." I've used it like 3 times since! And now i have a 4th task for it. And pick up their $15 6-inch digital micrometer while you're at it; best tool I own.
Old 02-02-2013, 09:04 AM
rlme36
rlme36's Avatar
Well that answers my question about what to use in the front diff
I've never seen it at autzone and I am there all the time hawking the Castrol German oil for other cars. I'll have to take a look again.
+1 on ordering from the above source
Old 02-02-2013, 10:16 AM
Ed Hughes
Ed Hughes's Avatar
Better order more, you won't want to run 1/2 full.....
Old 02-02-2013, 10:19 AM
Ed Hughes
Ed Hughes's Avatar
Pep Boys by my house carries it too, it really is pretty common.
Old 02-02-2013, 10:25 AM
993_TJC
993_TJC's Avatar
Gallons- quarts
Details details.
Old 02-02-2013, 10:30 AM
Cactus
Noodle Jr.
Cactus's Avatar
Gallons- quarts
Details details.
Go on Lufteknic.com and order one gallon of Mobil 1 Delvac 75/90.
Quick Reply: Transmission fluid for '95 993...
