993 Forum 1995-1998
Need tire size advice !
Old Dec 17, 2012 | 08:56 PM
holsen12's Avatar
holsen12
Default Need tire size advice !
Having just repaired flat spots in all 4 rims for my C4S, and also needing new ties, what opinion is there on running slightly wider/taller tires ? I understand Porsche did extensive tire size testing on the RS and concluded that 235/40 and 295/30 were the optimal sizes for that car…
Currently running 225/40-18 and 285/30-18 (stock) and thinking about 235/45-18 and 295/35-18 on 8x18 & 10x18 rims (see photo) I think the OD on the bigger set are within spec (to each other) relative to the anti-lock brake system, so I wouldn’t expect any issues there.
I live around Boston, and the roads here are sometimes terrible. Wondering if a little ‘cush’ at the wheel is in order or if the added size will seriously upset the handling.
Any opinions on sizing ?
Old Dec 17, 2012 | 09:33 PM
Bill Verburg's Avatar
Bill Verburg
They did, but they settled on 245/645 & 285/645 x18 on 8.5 & 10 wheels
closest street size in 245/35 & 285/30 x18
Old Dec 17, 2012 | 10:03 PM
kjr914's Avatar
kjr914
google "tire size calculator" and have at it. Here's the one I like:
http://www.miata.net/garage/tirecalc.html
245/35-18 rub in the front a little on my C4S. Taller tires will throw off your speedo. You aren't super low, so you shouldn't have rub issues under compression unless you have no camber. I can't fit a 245/40 in the front due to having little camber up front.
Old Dec 18, 2012 | 09:34 AM
Bill Verburg
Even 225/40 will rub the inner wall at full lock, that's not an issue though, in front anything taller than a 225/40 will tend to rub through the plastic inner liners, RS and Cup uses different liners to avoid that issue, but again the the higher the ride height the less of this sort of rubbing will occur
Old Dec 18, 2012 | 10:11 AM
Robert993TT's Avatar
Robert993TT
Why not downsize to 17" rims if driving a lot on terrible roads? I would think that would be the best answer to your problem.
Old Dec 18, 2012 | 10:37 AM
RonCT's Avatar
RonCT
Moderator
I'm just south of you in CT and would stick with stock sizes. Just shop for the best tire characteristics that meet your needs. Tire Rack's reviews / tests are a great research resource. Very happy with the Sumitomos on my car, but probably would have gone with the Conti DW if they were in stock at the time.
Old Dec 18, 2012 | 11:04 AM
Bill Verburg
I agree, if road surface is a major concern then 17's w/ a 45 & 40(or more) series tire will be way better than 18's w 40 & 35 series(or less) tires
Old Dec 18, 2012 | 12:28 PM
Leon993's Avatar
Leon993
I have to agree with Robert, downsizing to 17s is the way to go.
Provided you lower the car to Euro specs, 17s look gorgeous on the 993. In my opinion, its the perfect size for the car. Also, tires are slightly cheaper and significantly more robust than larger diameters.
Old Dec 18, 2012 | 02:30 PM
IXLR8's Avatar
IXLR8
Originally Posted by Bill Verburg
Even 225/40 will rub the inner wall at full lock.
Even a 205/50 x 17 will rub at full lock, and that is with Porsche approved N tire installed. At least the Michelin PS2s do.
I recall a thread from about a year ago with some members stating that 18s don't rub. Cripes, stock 17s rub.
Old Dec 18, 2012 | 04:22 PM
Robert993TT
Here is a picture of my turbo with OEM winter rims. The rear tire is 225/45/17 and front 205/50/17. There are no problems with grip. The car feels a lot more comfortable. The OEM wider 17" rear rims have 255/40/17 tires if I´m not wrong. That would be my choice If the summer roads would demand it. I think the 17" rims fit the car quite nice.
File Type: jpg
Old Dec 18, 2012 | 09:42 PM
nile13's Avatar
nile13
OP, you don;t really want 235/295 combination for several reasons. A lot will depend on the rest of your suspension and sway bars, but this will give you a fairly significant understeer. As does your current 225/286 combination.
If you chose to stay on 18" wheels, try 225/265. Maybe 235/275. Maybe 235/285, although that's stretching it a bit. In all these sizes stay with 40 ratio on the front, 35 on the rear.My own car is on 225/40 and 265/35 and it's fairly neutral. Anything more on the back and it would start to push.
PS. All of this richly irrelevant on the street. Especially around here.
Old Dec 19, 2012 | 12:10 AM
Knight's Avatar
Knight
I would for sure stick with the stock sizes or if you put on less performance oriented tires (all seasons) ride quality will improve.
Off topic, what kind of wheels are on your car? MY02s I'm guessing, but always thought these wheels were for NB cars, wasn't sure about fitment for WBs.
Old Dec 19, 2012 | 12:46 AM
nile13's Avatar
nile13
WB wheels = NB wheels + spacers (from factory).
Old Dec 19, 2012 | 02:06 AM
holsen12's Avatar
holsen12
Nile13 is correct; the rims are MY'02 with spacers in the rear. 5 flat spots on 4 rims in one year... the downside of a cast rim. The 'Big Dig' here in MA means we neglected the rest of our roads and the rims have taken a beating.
My avatar pic shows Fikse FM-10's; one of the rears was claimed by a granite curb... The MY'02 are allot easier to keep clean, and do show off the drilled rotors a bit better too.
I'm reluctant to go to a 17" rim... I think the car looks awesome with the 18"s, and further mod cash is reserved for suspension changes.
The car has Bilstien HD + H&R lowering springs (lowered to a bit above RS height) and has been completely gone thru and aligned by EPE. It has a bit more camber and toe than stock. I'm considering RS front uprights and ERP links in the rear to get some adjustability back. Bump-steer is something of an issue on some the 'crowned' freeways, crossing lanes at 80mph+ (going over these 'crowns') makes the car want to steer itself. Takes a bit of getting used to. Rt 3 south is the worst offender on this score.
The understeer issue cited by nile13 is worrisome. Oversteer I can deal with, understeer is a bit scary… So wider in front without wider in back is probably a bad idea for me.
However, my thinking is that a wider tire will change the sidewall to rim geometry a bit and add some ride compliance and flat-spot reduction. I intend to do some AX, but no DE or tracking. Well, maybe some DE. But my C4S is intended as a ‘3 season’ daily driver.
I'm considering the Bridgestone S-04 or the Michelin Pilot Sport AS Plus. I have a buddy who has a 993TT with the S-04 and he recommends them, and I have the Michelins on my wife’s MBZ E-500 wagon, and for and all-season tire, they’re pretty danm good. Ideally, the tire has ‘stick’ in wet as well as dry conditions.
Keep the advice coming !
Old Dec 19, 2012 | 05:39 AM
Robert993TT
I use 5 mm (front) and 21 mm (back) as recommended here for the rims I use on the picture:
http://www.pcarworkshop.com/images/3...1998_64028.pdf
