Performed some recent upgrades to the interior of the car; in the below pic, there are 4 switch / electrical upgrades (not including the stereo). Can you spot them?
2 out of 4 so far. The new **** above the stereo is the Rear Foglight switch; the gauge above the hazard switch is a Voltmeter. I wasn't counting the steering wheel or pedals; I consider those more "mechanical" upgrades.
Ok. 3 out of 4. The toggle switch to the left of the steering wheel is the Oil Cooler Fan override switch. The last one is a tricky one as I didn't mention that the car doesn't have a rear wiper. The last one is the middle switch between the sunroof and rear spoiler. I used the sunshade switch for a Targa as the switch for a garage door opener. Thanks for playing!
Alex, your earlier posts on voltmeters was highly informative reading. I followed them closely but wanted to do an analog gauge instead. I took some digital multimeter readings at the battery directly and found that if I wired the positive to the sunroof switch, then I got almost the same reading as at the battery directly (about 14.3v vs about 14.4 at the battery), so I figured this was close enough for an analog gauge. As a result, the gauge switches on with the ignition. The voltmeter required no cutting so I can easily revert back to stock if desired.
For the rear fogs and oil cooler switches, I followed the instructions on p-car.com; for the longest time, I only had the rear fog switch installed (just because that blank space was bugging me), but then went the whole way and ran the wires and bought the light sockets and put in actual rear fogs just like the ROW cars. Below are some close-ups.
It certainly is.
With what and how did you make the housing for the gauge?
BTW, if that gauge is like that on my old BMW motorcycle, there is a small hole in the back of the case so that you can slip a screwdriver into it to get to an adjustment pot (verify that first). Adjust it to be accurate at 14.2V from your viewing angle (due to parallax).
