Steering - slight "groan" at full lock and low speed sometimes
Should I be concerned? I've had the car for almost a couple of months now and it's still under the limited used car warranty. Is this slight groan (which I'm not certain I can actually hear or whether I'm actually feeling it through the steering wheel) indicative of a power steering problem of any kind? I hear/feel it in places like car parks. It's intermittent too.
I just had something similar and it turned out to be the suspension camber bolts were loose. All tightened up and there's no more groan on cornering or during parking.
One other thing to look at is a wheel bearing going... |
Thanks for replying so quickly :cheers:
Originally Posted by CamsPorsche
(Post 10002720)
Check that you have sufficient power steering fluid. Once that gets low (or empty) you can get bubbles in the system, the pump then cavitates and you hear the groan and feel the vibration through the steering wheel. If it is lack of fluid, top up with the correct stuff (pentosin) and keep an eye on it - generally it shouldn't disappear unless you've got a leak. A leak could be steering rack, pump or split pipes.
+1 on the power steering fluid. Check that first.
Originally Posted by stickypatch
(Post 10002719)
Do you have a AWD 993 with possible worn CV joints out front? Is the "groan" more noticeable when coming down car park ramps onto the flats at full lock? |
It's never a good idea to crank the wheel to full lock; it's supposed to be tough on the power steering pump. Instead, it's best to know where full lock is and then make sure that you don't hit the steering stop.
I had persistent groaning when turning and going down-hill/up-hill at the same time, typically when entering or exiting an underground parking.
It turned out to be the front sway bar bushings that needed greasing. Easy and cheap to fix. |
'where' do you hear it from?
meaning out @ a corner / pump area / rack / other? funny... I posted exactly the same question a coupla weeks back... 100 views, 0 replies. You garnered 7 in a few hours: https://rennlist.com/forums/993-foru...heel-rest.html I let it go at the time but now wonder... what gives??? 8-)... Bueller? Like you said, intermittent and don't exactly feel it thru the steering wheel like I would from a typical pump or rack issue I've experienced in the past. We had a Nor'easter here and then I've been travelling since I posted that so I unfortunately haven't had time to get the 'bish up on stands to try to discern it for mesself, but had hoped for some insight from youses har - surprised @ the crickets 8-/... |
(Post 10004720)
Groan was low PS fluid for me.
Had the same issue on my R32. Power steering fluid was below the low mark.
Originally Posted by Mark in Baltimore
(Post 10006264)
No real data to support this claim, but I think Fridays and Saturdays are the worst time to start new threads since people are busy with kids and other activities that pull them away from the computer. The page count probably shows that lots of folks are viewing the thread on smart phones but don't have the time or patience to answer.
I checked my power steering fluid level - while the car was idling as per the manual. The level was at the high mark on the wee dipstick.
