Questions on squealing belts
#31
From the technical bulletin Alex posted above
"The new version pulleys can also be installed on the 911 Carrera. However, the previous version belt
must be used."
Interesting note. The verbage for the turbo was "must" replace pulley. Carrera "can" replace pulley.
Asofine, you pickup that with the new pulley on a Carrera (non turbo), you still use the old belt?
must be used."
