Wide Ovals? Swap onto Fabspeed mufflers?
I came across the stock exhaust tips while going through the box of stock parts that came with my 1996 C4S. They appear to be wide ovals. "EP 7110" is stamped on the underside.
The car currently has fabspeed mufflers and tips. Would these be a direct swap with the fabspeed tips? If so, I am going to have these wide ovals polished.
The car is currently in storage so I unfortunately can't go and check my self.
I doubt they will fit. Going through the same dilemma now. The outlet pipe on the can is much shorter than stock on my set of Fabspeeds. Been thinking of making an extension pipe to be able to put wide ovals on them, though. Good luck.
