Brake job time
Brake job time
On my way to spec the rotors to see if they need a change.
For my fellow central Florida drivers, shipping from almost anywhere gets expensive to down here. Have any of you found a Orlando aftermarket location to pickup rotors from? Have not priced them from the Dealer yet, trying to avoid the shock!
Thanks,
Neal
Thanks,
Neal
Yep, it is time. The info I can find says thickness is 32mm. Wear limit is 1mm per side, so my 30.6mm is pretty close! Seeing as it is time for pads, I will do it in one shot.
