993 Forum 1995-1998
Should I pull the trigger?
Old Oct 15, 2012 | 11:33 AM
FabianS's Avatar
FabianS
Default Should I pull the trigger?
I'm considering purchasing a nice 95 C4, but I have some reservations with the mileage, which is 145,000 kms. The car otherwise has been maintained well, and has new brakes all around, as well as about $6000 in aftermarkes suspension, exhaust, etc. My concern is that at 145,000 kms if I drive it for 5-6 years it will have 200,000+ kms on it, which seems like an awful lot. The price is reasonable, but I wonder if I hold out for a while I might find another car with less kms for just a bit more. What does everyone think? I will of course be having a PPI and compression test done...
Thanks.
Old Oct 15, 2012 | 11:44 AM
boman993's Avatar
boman993
I don't think there is a right/wrong answer to this.
It really depends on what your priorities are ~ If you care about resale (you're
going to sell it in 4-5 years for sure), then wait for another one with less kms.
If you just want a well sorted car, and you love everything about it and will
drive it to 300000kms without looking back; pull the trigger!
Old Oct 15, 2012 | 11:52 AM
MartinC2S's Avatar
MartinC2S
Personally I would wait. I know it's tempting to pull the trigger on these cars but I think you'll be able to find something better with lower kms. I just bought a '98 C2S with 35k on it last month after looking for over a year. They're out there, you just needs to find them and wait a bit.
Old Oct 15, 2012 | 11:55 AM
FabianS's Avatar
FabianS
I should probably add that there aren't very many up here in Canada, and that the prices up here are quite a bit more than in the States...
Old Oct 15, 2012 | 11:56 AM
Magdaddy's Avatar
Magdaddy
the value of the aftermarket goodies shouldn't be ignored. The previous owner of my C4S, put $7K into the car, just 500 miles before I bought it.
If you intend to drive the car, and not worry about the usual effects of doing so...rock chips, acquimulated mileage, hell maybe even door dings...then go for it if it all checks out.
A well cared for driver that has desireable performance mods is a good thing, it's a great thing if it's at a good price. I've put almost 30K miles on my C4S in the short 28 months I've owned it. It had 63K on it when I bought it, nearing
93K shortly. I'll roll into six figures early next spring without a care or concern.
Best of luck
Old Oct 15, 2012 | 12:14 PM
doberdog's Avatar
doberdog
I sold a 50,000km car for top dollar and purchased one with just over 100,000km and it runs better, has had the top-end repaired, new clutch and the engine is just as strong. Don't forget, the car with higher km's might have had all the repairs that these cars often require. Check out the history of the car over anything else.
I'd only buy it if I got a great deal. My C4S was $35,000 with just over 100,000 km's in Vancouver.
Old Oct 15, 2012 | 12:16 PM
mdude's Avatar
mdude
Thanks.
High mileage should not necessarily deter you. You may wish to consider:
1) Your budget, obviously. A lower mileage car is going to cost much more but not necessarily less expensive to upkeep. Which leads to the 2nd point:
2) A high mileage car that has been through the most likely wallet busting repairs (i.e. clutch, top end rebuild) is IMHO a better value than a lower mileage cars w/ those expenses lurking. Don't know the prices up in Canada, but using the States as an illustration: a 145 km 95 C4 will go for around $25-$28k. The same car for 100km will go for $29-33k, and maybe $35k for 40-60km mileage. If the 1st car already has clutch etc taken care of, it'll be much cheaper to own than a lower mileage car w/ $10k in repairs waiting in the wings.
Good luck hunting. Keep us posted.
Old Oct 15, 2012 | 12:33 PM
FabianS's Avatar
FabianS
The car is $26k and has original top end, and clutch. I had another Rennlister check it out for me as it's out of Province, and he thought it was a very nice car.
Old Oct 15, 2012 | 12:54 PM
doberdog's Avatar
doberdog
You need to consider a PPI and negotiate the price based in the condition. No top-end rebuild might be a deal-breaker.
Old Oct 15, 2012 | 01:04 PM
FabianS's Avatar
FabianS
Well, the asking price was $29,000 so he has already moved considerably. Most of the 993's I've seen up here with 100,000 ish kms got for around $35-40,000.
Old Oct 15, 2012 | 01:18 PM
cmat's Avatar
cmat
Also, make sure the mods are things you really want. Just because someone spent a lot on changes doesn't mean they are right for you. Suspension changes especially need to be tailored to how the car will get used. Over time I wound up removing all the mods that were on my car.
Old Oct 15, 2012 | 01:26 PM
Seamless's Avatar
Seamless
Is the car possibly a red one from Winnipeg?
Old Oct 15, 2012 | 01:32 PM
FabianS's Avatar
FabianS
Yes. I'm having a PPI and compression test done on Thursday.
mdude's Avatar
mdude
Do not forgo the PPI, with leakdown and compression.
Find out where the car has been serviced (preferably an air-cooled specialist) and call the shop and chat up some info.
Old Oct 15, 2012 | 01:37 PM
FabianS's Avatar
FabianS
I won't forego a PPI or compression test, but a leakdown is out of the question...Porsche dealer wants WAY too much, and it is where the car is serviced, and the indy doing the PPI and compression test doesn't have the means to do a leakdown.
