Driver's seatbelt retraction is tired - is it an easy DIY?
My driver's side seatbelt retraction is a bit tired and won't quite retract fully without a little bit of "encouragement". Just wondering if there is an easy fix? Or if somebody has perhaps done a DIY replacement and can comment on the complexity?
Not sure how to fix, and definitely not something you want to experiment with...
An alternative "fix", someone's selling a set for $200:
https://rennlist.com/forums/for-sale...out-993-a.html
Official Wednesday AM Red Bull F1 test driver
I'm dealing with rebuilding the belts on a '73 914 I'm restoring and will probably have a place called seatbeltplanet redo them. They do work on Porsche belts- could check them out...
Is it the retraction mechanism that is dragging - or the seat belt itself dragging on the 'hoop' attached above your shoulder?
I've had this issue on one car: the cure was to lift the belt and clean the built up crap from the guides rub strip.
