after-run cooling fan - how long is it supposed to run when it runs?
Nothing's more gratifying to me than when one of my cars' after-run cooling fans pumps on - signifies to me that... well... I've done good 8-).
Question on the 993 tho... how long is it supposed to RUN once it comes on?
I've searched / read, seems all I find are those questioning if that's 'normal' for it to be coming on (duh).
Reason I ask... mine comes on... for like all of maybe 2-3secs... maybe once, maybe twice, maybe thrice.
Shouldn't it run longer before shutting off? In my former //S6 (i5t) it'd run for seemingly 30-60sec's.
Querious.
Paul
CT
past: '87 930 | '58 TR3A | '01 //S8 | '95 //S6 6spd | '88 ///M5 | '87 190E 2.3-16 |
Querious.
Paul
CT
Querious.
Paul
CT
Querious.
Paul
CT
"Rear fan temperature monitoring: If the ignition has been switched on for at least 30 seconds, the engine compartment temperatur willl be monitored for at least 20 minutes after the ignition is switched off. If the engine compartment temperature exceeds 167degF/75degC during this period, the rear fan will switch on. When the temperature drops below 158degF/70degC, it will switch off. Temperature will then be monitored for another 15 minutes. If the temperature limit is not exceeded during this additiional period, the control unit will switch off."
I have noticed that after a spirited run, especially during hot weather, the fan will run for a period after I shut the engine off. I don't think I ever remember it turning on for only 2 to 3 seconds though. Sounds like a monitoring issue. Sometimes when I know the engine is quite hot, I'll leave the rear spoiler in the up position to help dissipate the heat from the engine (not sure if this really helps).
Good luck!
As Gary said, it should run intermittently for up to 20 minutes. I have actually timed it once to check and it stops after 20 minutes. The fan never runs for longer than 5-10 seconds at a time. More like 5 in my experience.
It's all normal!
It's all normal!
thanks for the replies guys, appreciate it
good to hear it's normal - tho I still think it should stay on longer 8-)... not sure how quick little bursts like that can be effective but hey what do I know...
Paul
CT
Paul
CT
Paul
CT
Paul
CT
