993 Forum 1995-1998
Cam Tower Wear Question
Old Sep 30, 2012 | 06:54 PM
Vorsicht's Avatar
Vorsicht
Default Cam Tower Wear Question
So, I have my engine apart and I'm cleaning the CAM towers and I see this. It is along the top. What does this indicate? Each picture is of one third of the housing from front to rear.
File Type: jpg
File Type: jpg
File Type: jpg
Old Oct 1, 2012 | 04:25 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
I see some wear on the cam bearing surface; is that what you are referring to?
The rest is simply part of the manufacturing process, however I do note the "notch" along the sealing surface.
Old Oct 1, 2012 | 07:19 PM
AOW162435's Avatar
AOW162435
Seared
Maybe someone performed a spark plug change with the valve covers off and rotated the ratchet extension again the tower in those spots?
Andreas
Old Oct 2, 2012 | 01:30 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Like Steve mentioned, some machining cleanup can vary due to core shifting in the casting process.
