993 Forum 1995-1998
Sponsored by: DashLynx
Odometer not working
Old 09-30-2012, 03:18 PM
MM993
MM993's Avatar
Default Odometer not working
I just had the car up on jack stands for a few days (SSK install) and once back on the ground the Odometer stopped working. Could this just be a coincidence or did I disconnect something by picking up the car up and then down? I wasn't close to any wiring under the car. The Odometer was fixed about 8 years/15K miles ago by a PO. 46K miles on the clock now.
Thanks for any advice!
Old 09-30-2012, 03:26 PM
Floodj
Floodj's Avatar
Does the speedometer work? If so my first thought would be the notorious Odometer gear. Do a search here and on PCA.org and you will find plenty of information about how to fix it.
Old 09-30-2012, 03:46 PM
MM993
MM993's Avatar
Floodj; Yes the speedo works, and I have checked out the great DIY video for fixing the gears. I just wanted to get any other feedback before I pull everything apart.
Old 09-30-2012, 05:22 PM
nile13
nile13's Avatar
Yep, gears. A search would bring up dozens of posts on this.
Old 09-30-2012, 05:45 PM
MM993
MM993's Avatar
Nile13, Did the search, just making sure. Thanks
Old 09-30-2012, 06:00 PM
e9stibi
e9stibi's Avatar
I just had mine repaired by North Hollywood Speedometer for 130 usd. Highly recommended.
Old 09-30-2012, 06:29 PM
nile13
nile13's Avatar
No problem, Mike. I was just pointing out that I have not seen any other reasoning for this issue, unfortunately, when I was doing mine.
Old 09-30-2012, 06:42 PM
IXLR8
IXLR8's Avatar
If you plan on doing the repair yourself, Odometer Gears has the parts and they also show PDF installation instructions.
Old 09-30-2012, 10:46 PM
MM993
MM993's Avatar
Thanks guys, off to get new gears this week. e9stibi - thanks for the recommendation for NHS.
Old 09-30-2012, 10:57 PM
vincer77
vincer77's Avatar
I started to do the gears myself but saw that I was going to mar the housing too bad. Sent it to No. Hollywood and it came back beautiful.
Old 10-01-2012, 12:01 AM
DocTock993
DocTock993's Avatar
Another vote for North Hollywood for a gear replacement.
Fast and professional work.
Old 10-17-2012, 03:56 PM
MM993
MM993's Avatar
Default Gears1
Follow up to my Odometer issue. It turned out to be just a coincidence after working on the car for other things. Timing is everything!
Major thanks to Marc/Mgianzero for his DIY video on replacing the two gears without taking the whole thing apart. I did review the DIY’s from Pcar.com and Odometers.com to be as educated as possible, but Marc’s video made everything very clear. Odometers.com made it easy to order the gears online and I got them in 3 days.
My overall 2 cents is as follows; It’s not a hard DIY at all, just take your time. Buy both gears; I was shocked to see the large gear being the problem vs the normal smaller gear.
The advice of cleaning everything out with compressed air for any broken teeth is correct, however in my situation, I needed to pick out all the teeth wedged in the large inside gear with a paperclip. I also recommend a jewelers loop/magnifying glass to inspect the inside gear from all angles. A must is to get the type of thin tweezers Marc used in the video; they would have cut my time easily in half vs regular tweezers. The photo shows the new gears and my old large melted gear with all the teeth I pulled out.
Old 10-17-2012, 06:17 PM
gaby1088
gaby1088's Avatar
wow crazy how they get!! my odometer is working fine, but for X reason i have to tap on my speedometer for it to measure speed, the odometer still works though jaja.
Old 10-17-2012, 06:53 PM
nile13
nile13's Avatar
You have cold soldered contacts in the speedometer more than likely.
Old 10-17-2012, 08:20 PM
os993
os993's Avatar
Palo Alto speedometer also does a good job fixing this.
They say NEVER reset your odometer while in motion - that screws up/breaks the gearing.
Quick Reply: Odometer not working
