Rattle debug Q on suspsension
A bit of background.
I had JIC cross on my cab. Switched the struts/droplinks/RS swaybars to the coupe.
There was a thumpity rattle coming from the driver front at slow speeds on bumpy roads (prob there on higher speeds and smoother roads, but engine noise overrides it) on the cab. It is now on the coupe. It was gone for awhile after install, but is there now. I've had it looked at, tightened, tracked it several times...nothing is criminally loose.
So I'm wondering what it could be, and how I'd go about debugging it. Could I unhook the drop links from the sway bar, and at least eliminate the sway bar as the culprit that way? Would that potentially cause mayhem if I had an unhooked drop link, even just for noise/thump testing?
Any suggestions on how to methodically chase this gremlin would be most appreciated. I realize it could be in the shock itself, but I'm loathe to pay to take it off, ship it, wait...wait...wait...then pay to reinstall and realign...only to have it be something else.
Thanks,
Thanks,
put the corner you want to test in the air, pry the wheel up, it helps to have help to do this, you can often feel the slop through a hand on the shock than hear it.
