Re gearing
#61
When I post i try to use a standardized setup, 285/30 will be a very small amount shorter, how much depends on the specific tire, so the net gearing will be a small amount shorter.
The big difference between /21 and /31 is in 1 & 2, the /31 is more of a track oriented setup, but I like it for street use too. The taller 1 & 2 gives you shorter drops for 1 - 3
#62
You don't need them for street use but steel syncros, motorsports bearings and shift forks make for a nice transmission, while in there think about the lsd, a GT 40/60 would be a perfect addition for an open diff, or just update the plate stack w/ GT components if it's already got an lsd
#63
You are in great hands!
Agree about Copans! Planning on syncros, etc for the transmission. I think we are leaning towards PMS parts for the existing LSD and my intended use but we will see.
#64
