Driver's window lifter rail problem and Q
My left window stopped working with a loud clunk, and taking the door panel off, I found the glass had come loose from the window lifter rail. Check out the pic!
I plan to order new rubber and L+R lifter rails (found 'em in PET). My question is what kind of glue to use to glue the rubber to the metal track, and do I also glue the glass to the rubber?
Finally, what kind of grease should I use to lube the system (since I'm in there).
Thanks!
Thanks!
Thanks!
Thanks!
I would ask the parts people at Sunset to see if there is an adhesive required.
They sell Wurth Bond+Seal in a small tube, PN 000.043.204.38, but it doesn't
seem to be in the PET. This might work.
When I lubed by window mechanism I used Wurth HHS-K.
Good luck,
-bruce
