aftermarket front drop links
HI
I bought a new set of aftermarket drop links from Tarett for my C2
but I found it doesn't fit the drop links keep on hitting the struts.
I'm using an H&R sway fabric with PSS10's
I've taken some pictures hope someone can shed some light on this matter
also look pictures of the stock drop links.
they look different
they look different
I HAVE...
PSS 9s, not PSS 10, Tarrett Engineering Drop links and they fit fine. I also use 993RS sway bars.
I would call Tarrett Engineering and ask them for help.
Sorry to hear about your problems..
Length of drop links: Front & Rear are different
The "stock" drop link you are picturing is for the front. So with Tarrett, you have the longest drop links on the front, similar in length to the "stock", and the shortest on the back. I am certain you know this, but just in case you don't.....
