993 Forum 1995-1998
993 tiptronic experts?
Old Aug 15, 2012 | 04:34 AM
rob0001's Avatar
rob0001
Default 993 tiptronic experts?
Got an '95 993 tiptronic. Transmission is working very smooth but when playing with the throttle, I hear a lot of clunk clunk noises coming from the transmission or differential, hard to tell. Dealer is telling me to rebuild the tiptronic transmission. No need to tell me but I belive that full rebuild is not needed, only repair. Could it be too much play in the differential gears or the 180 degrees return axle/ gears to differential? Does anyone experienced this as well? Or any insight were to look for when opening the tiptronic?
Old Aug 15, 2012 | 07:10 AM
tctung's Avatar
tctung
My Tip is the same. Interested in learning the root cause from an expert, too.
Old Aug 15, 2012 | 10:27 AM
justin-in-athens's Avatar
justin-in-athens
I would just try servicing the gearbox and dif with new fluid and a filter.
Try using 6 quarts of ZF Lifeguard5 in the gearbox with an OEM filter. ZF makes the transmission in the 993--contrary to popular belief it was not a mercedes unit until the 996.
The dif holds about .75qts of 75-90wt synthetic NON LSD nfluid (unless you have an LSD).
You will need a brake bleeder or will need to fabricate a fill unit of some kind--but that should be easy if you are so inclined to do this project yourself.
See further reading here:
http://forums.pelicanparts.com/porsc...-pictures.html
http://www.thectsc.com/index.php?p=p...id=14&parent=0
I have a filter and pan gasket that I don't need if you'd like to purchase them
Old Aug 15, 2012 | 01:01 PM
77'3.6vram's Avatar
77'3.6vram
I believe the ZF unit used in our 993 Tip's is very similar to the ones BMW installed around the same time. It maybe helpful to speak with an experienced BMW technician as they should be more familiar with the ZF tranny in question.Just a suggestion.
Old Aug 15, 2012 | 02:18 PM
rob0001's Avatar
rob0001
Filter and oil has been changed up to factory spec. When changed, pan magnet and old oil was clean. The noise is defenately mechanical. Correct that the ZF tranny is used at BMW, Jaguar, Volvo (ZF-4HP22) but Porsche (ZF-4HP22HL) has the additional 180 degrees return axle and gears to diff. which I suspect so I hope on a ZF tiptronic expert opinion
