993 Forum 1995-1998
Door Handle/Latch Issue
Old Aug 14, 2012 | 03:45 PM
certz's Avatar
certz
Default Door Handle/Latch Issue
I am having an issue with the door latch sticking, here is the scenario: I use the fob to unlock the car, grab the door handle and pull the small lever in the handle to open the door. The door unlatches and opens but the small lever sticks and does not release (it moves but there is no feedback, it is just loose). So, when I try to shut the door the latch is in the wrong position and bangs/bounces off the door stricker plate.
I looked at the exploded view on Auto Atlanta and I cannot really tell what might be causing the latch to hang up. Could it be the lock mechanism or some cable/rod that does not seem to be shown. Anyone have this happen? Any thoughts? I would prefer not to have to start getting in the passenger side an crawling over the console
Old Aug 14, 2012 | 03:54 PM
XR4Tim's Avatar
XR4Tim
Could be just about anything inside the latch binding up. Does it do it when you open the door from the inside? Have you tried lubricating the latch?
Old Aug 14, 2012 | 04:04 PM
geolab's Avatar
geolab
You know that whilst passing all the gears on the track, the higher you go, the more air goes
into the lock mechanism.
On the longer run, gunk accumulates there.
One (1) x can of WD40 and an old t-shirt.
Do this door open, and t-shirt placed vertically under door.
Place the WD40 straw tip on the small black lever upper and lower swivel points and spray a good thrust on the joints. Any excess oil inside is good, no worry.
Tap the lever in out so that it liberates and move freely.
It will liberate.
Only happens on fast cars, sorry ...
Regards
Old Aug 14, 2012 | 04:38 PM
JimPA's Avatar
JimPA
WD40 may provide a short-term fix. On my car the trigger swivel points were fine; the interior components were sticking.
For more permanent relief, remove the inside door panel, access and loosen the bolts/nuts holding the exterior handle and lube the mechanism with grease. IIRC, there's a rod that's actuated by squeezing the trigger. There's probably a DIY somewhere on this forum if you search.
Old Aug 14, 2012 | 04:56 PM
certz's Avatar
certz
Thanks guys. I will start with the WD-40 approach and if that does not improve it then it is on to removing the door panel and rooting around.
Old Aug 14, 2012 | 06:13 PM
kjr914's Avatar
kjr914
I recall seeing a thread less than a year ago about a very similar issue with pics of the innards of the door handle...
Here:
https://rennlist.com/forums/993-foru...ith-key-4.html
Old Aug 14, 2012 | 09:55 PM
Christian J's Avatar
Christian J
It's worth taking them apart and using grease on the internals. I had the same issues and while wd40 will loosen things up my greased handles have a light and smooth action that is heavenly. While you're in there change your lock actuators and you'll be good for another 15 years. Makes for a good winter project.
Old Aug 15, 2012 | 08:48 AM
ble2011's Avatar
ble2011
FYI - WD40 is not a good lubricant. In fact, it will remove grease. It was designed as a water displacement. I would avoid using WD40 on anything you want greased.
Old Aug 15, 2012 | 10:56 AM
certz's Avatar
certz
Thanks kjr and Christian - looks like I need to start a winter project list.
