Power Antenna wire
Hard to tell from the photo, but it appears that the thin black wire that powers the antenna amp is plugged into a connector to a white wire. That should work fine, as long as the white wire gets power when in AM or FM mode. I have an Alpine unit and it uses a blue wire for this.
Thanks. I am getting the radio removal tools and will check power to there. The photo is from an earlier rennlist posting a few years back. My radio works well except when I drive into the parking garage at work and when I drive at night--no back lighting. (BTW: I have a CDR-210 Becker unit, original with car??).
Has your car had a new windshield? Perhaps the antenna lead off the windshield isn't connected or has been spliced. If you raise your trunk lid and shine a light into the recess behind the hinge where the antenna lead goes down from the windshield, hopefully, you'll see the lead and connector plugged into the black box.
