993 Forum 1995-1998
KW strut size?
Old Aug 7, 2012 | 02:45 PM
David in LA's Avatar
David in LA
Default KW strut size?
Does anyone happen to know whether the KW strut is 12mm or 14mm? TIA
Old Aug 7, 2012 | 04:26 PM
CarreraX's Avatar
CarreraX
Mine worked perfect with my stock strut bearings if that helps.
Old Aug 7, 2012 | 06:08 PM
sfl993t4's Avatar
sfl993t4
Hello
According to Rennline 14mm front and 12mm rear. Hope they are right as I've just ordered the top mounts for my KW v3
Steve
Old Aug 7, 2012 | 10:44 PM
David in LA
Originally Posted by sfl993t4
Hello
Steve
Hi Steve - Did they tell you via email or was the info on their site? I am also looking at top mounts. Do you know offhand what part numbers you ordered (not sure if I will be going with Rennlines or another manufacturer).
TIA!
