Burnt fuel smell in cabin?
Recently I've noticed a smell of partially burnt fuel in the cabin of my 993. It's not super-stong but definately there to some degree.
My wife is pregnant at the moment so it got me a little paranoid that it may not be the best thing..
Just wondering if anyone else has this experience and if it's anything to worry about.
Appreciate any thoughts
If your valve covers are leaking oil, they drip onto the tops of your heat exchangers. Some of that oil can make it into the insides of the heat exchanger and when it does, you will get the smell of hot/burnt oil into your cabin, depending on what extent you have the heat on.
If that is the case, you will have to remove the heat exchangers and flush the insides out with a water based degreaser. My heat exchangers were coated with oil internally when I got my 993 but are spotlessly clean now. I replaced all valve cover seals and everything has been bone-dry since.
If you remove the 90 degree rubber hoses that attach to the top of the heat exchangers, a trouble light and mirror will tell if you have an oil film within the heat exchangers.
And if you suspect an exhaust leak into the cabin, you can get CO indicators at safety supply and pilot supply shops.
***Of course with the A/C on full blast, I would check the luggage compartment for a fuel leak or odor. It could even be the battery gassing.***
