Looking for rocker panel clip PN
My lower rocker covers are loose at the front top. There is a plastic clip that bolts to the lower fender and then the rocker is supposed to snap into it (I think). Can someone help me with the part number? I need them for a WB C4S. I searched and also tried to download the PET w/o luck. Frustrated. Thanks in advance!!!
Yes it is grasshopper. A look to the right is needed ... see the 'Turbo' application listings? Those are the part numbers for the PhatAsses .. they just didn't change the picture and reprint those because there's so much 'cross over' ..
Isn't the 'clip' your looking for in there somewhere?
It is the #2 clip. So that would be the 999 591 990 one right? Is the M491/M495 correct? Want to make sure it isnt for an early car.
OK, I'll give in to JPP cult and ask here
The rear side of my driver's rocker panel is hanging down. This is NB car, black plastic non-painted rockers. It appears that clip is broken there. Any way to repair?
They are molded, I believe. Curious if anyone successfully re-attached the back of the skirt.
Odd that a passenger side skirt was detached on the back of my previous 993.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
There is the plastic clip and a couple of screws that hold the rear of the rocker up. In addition to the molded tabs that sit outboard on the rocker.
