Interior Makeover
Here are pictures of the back area. I wanted some stitching on the back cover like the classic 911's but it got left out. If I were to do it again, I probably would have mixed in some perforated leather here and there, for a more vintage look.
very nice work.
especially how you cleaned up the wire harness under the dash.
what have you done in place of the center console around the ebrake handle and shifter?
how do you like those alloy door handles?
and most important how much weight did you save going to manual windows?
very nice work.
The door handles are okay. I'm a little disappointed with the quality. They are just painted stamped metal plates. They feel solid and I like the design a lot. They would have been way better if they were machined and anodized.
I didn't weight the window lifter, but the difference can't be that big. The window motors are not that heavy and the manual lifter is definitely heavier than the powered ones.
I started out with the idea of weight saving, but I realize that the square weave carpeting and leather are both really heavy. So in the end, I accepted myself as being a poser, and just want the interior to look and feel nice, with a perception of light weight. I spend sleepless nights thinking about the manual window conversion but in the end I don't regret the totally unreasonable amount of money, because it feels so nice to crank the windows up and down. The same goes for the manual door lock.
Still want to do a better job with the underdash wiring. I think I can reroute the climate control harness to make it disappear from view. The harness for the switches will eventually be gone also, along with relocating/deleting those switches.
OH YEAH, very nice!!! Those seats look fabulous. I'm in the middle of a very similar project myself.
I eventually need to locate some of the non-airbag column parts; where did you purchase?
Thanks! Mostly from Pelican Parts. I've been getting stuff from the local Porsche dealer also. Just do a search here and you can get all the part numbers.
Thanks .. I like where your going with this .. a script on the vertical shelf cover would/could be awesome. I have thoughts about doing a 'lightweight' coupe in the future with all carpet back there ala RS but leaving the side covers inplace as well .. doing the lower seat belt retractor cover in carpet and leave the upper in vinyl, but now that you mention it .. perforated leather would be really nice.
Very, very nice. Like the leather Recaros a look as well as how the dash looks. Switches on the dash are also a very cool solution for the console delete. Did you think about have the shells of the Recaros sprayed in the color of your car? Would be totally different look.
Absolutely gorgeous. I'm getting a little tired of my grey interior, but don't think I could muster the time/energy/money. I like the Rennsport shifter suggestion.
