Steering wheel wobble at speed and during braking. Bushings the likely culprit?
Sorry for reintroducing a topic that seems to have been discussed at some length, but thought I'd run it by the community for some qualified opinions:
Had an opportunity for some quality time with my 993 C2S recently, 1000 miles of it, to be precise. During my trip i noticed that the steering has developed a slight wobble in the 55 - 65 mph range. I thought initially that it had to do with uneven surfaces (concrete on certain sections of highways over here), but it was also present on smooth sections of brand new tarmac, so there is no denying that there is an issue.
On braking the wobble is VERY noticeable, a new sensation as the car did not have this 2000 miles ago (which is what I have covered since I bought it about a year ago). The fact that the wobble is present both at speed and when braking makes me think that it might be the front control arm bushings, but I would appreciate some opinions. I take it that the brakes could be another contender, but the two PPIs I had done and the work which has been done on it since I got it do not suggest that it is a brake issue. Front wheel bearings? But at 23 K miles? Rotors?
The dry facts:
1998 C2S - 23 K miles
Original US sports suspension, bushings, dampers and all.
New tires with less than 2000 miles on them, balanced and correctly inflated. No flat spots (which I have noticed at least, but the tires are brand new)
No feeling of unevenness during braking through the pedal.
Feedback from mechanic 2000 miles ago was that (at least) some bushings were pretty worn, ditto for dampers.
Time to do the suspension and bushings? - and is this likely to solve the issues I have, do you think?
The dry facts:
Bushings would be my guess, mine did the same thing before i replaced them. If you jack up the car and use a pry bar between where the control arm attaches to the frame and you see lots of slop/movement thats probably the problem. Mine was pretty obvious when i did that. changing them made a huge difference.
Ok, thanks a lot, guys. I already have the bushings, bought them earlier this year, but haven't had a chance to get the job done, but now it seems I have to bite the bullet and have them done, along with new suspension. Would love to hear from anyone who has done the KONI FSDs in combination with M033.
I almost went with Koni then decided on the Bilsteins for more height adjustability. I did M033 and the Walrods at the same time and it was the best thing I have done for my car. It is perfect for street driving and the twisties. I do not track my 993.
Thanks, skl2. Bilsteins are my second option. My only concern with them, although I am not sure, is that the bilsteins will offer a harsher ride than the Konis. I'd rather have a slightly softer than a firmer ride, as the roads the car will eventually end up on are not particularly good. The car will not be tracked. What is the ride like with the m033 and bilstein combo? In terms of hard/soft?
Something to consider since it will cost you nothing to check/perform. The "index" method sounds absurd but I tried it (for my RUF 19s) and it actually worked!
Post #4:
https://rennlist.com/forums/993-turb...ferrerid=66189
Post #6:
https://rennlist.com/forums/993-foru...ferrerid=66189
Post #8:
Post #4:
Post #6:
Post #8:
