**check your intakes**
I've posted this before but I'll post it again, check you intakes for leaks, I've been feeling that my car was down on power at the top end for a while now, finally got around to smoking the intake and found a pin hole leak, last time idi this was 2 years ago.
bottom line, 10min of work and it's whole new car.
I actually use one of those party smoke machine which can be bought for $40. I pressurize the intake with couple lbs of pressurized air. Then just pump the party smoke into the engine bay and watch for the air leak creating a swirl pattern in the smoke.
This is more effective than trying to pump smoke into the intake itself.
I am a fairly avid wrencher, but this is new to me. What do you mean "pressurize the intake"? Can you explain the steps to pressurize it using an air hose? Thanks and I apologize for my complete naievete on this topic.
I went to home depot and bought a 3-3.5 inch rubber cap and fitted it with an air hose connector. I then removed the airbox and connect the cap up to the MAF. I then put very low pressurized air (2-3 psi) into the air hose connector.
The 993 manual has a porsche specific part and the same procedure.
Could you use Wurth Trace Powder Spray ??
http://www.pelicanparts.com/cgi-bin/...Powder%20Spray
phil.
phil.
In my case the leak was at a vacuum nipple that wasn't being used and was plugged off, the pin hole leak was around the plug, a small hose clamp was the cure
Thanks Bill, excellent advice... Not sure about vram cars, but with non-vram the intake should hold vacuum indefinitely. A quick check is to let the car sit for a couple of hours and pull the line to the actuator, you should hear it hiss, No hiss=vacuum leak.
when you turn the key the actuators cycle, I could hear the relay but could never be in 2 places at once to turn the key and watch the actuators.
This was my first experience w/ a quality smoke machine, it was an very efficient method to diagnose where the leak was.
The other issue I've been having is the lack of enough vacuum for long straights, the v-rams use a lot of vacuum so I just added another vacuum can. Hope it's sufficient, the non vrams need ~1/3 of the vacuum reserve
