p1123 CEL
thanks peter
Here's a list from my notes of the codes.
DTC Circuit Or Condition
1000 End Of Output
1111 Power Supply Wrong Voltage
1112 Ground In Idle Speed Control Circuit
1113 Ground In Full Load Contact Circuit
1114 Open Engine Temperature 11 Circuit
1115 Idle Control Interrupted
1121 Air Sensor Flow Circuit
1123 Oxygen Sensor
1124 Oxygen Sensor
1125 Air Temperature Sensor
1131 Knock Sensor 1
1132 Knock Sensor
1133 Knock Regulation Circuit
1134 Hall Sender Signal
1141 ECU
1151 Fuel Injector No. 1
1152 Fuel Injector No. 2
1153 Fuel Injector No. 3
1154 Fuel Injector No. 4
1155 Fuel Injector No. 5
1156 Fuel Injector No. 6
1311 Fuel Injector No. 1
1312 Fuel Injector No. 2
1313 Fuel Injector No. 3
1314 Fuel Injector No. 4
1315 Fuel Injector No. 5
1316 Fuel Injector No. 6
1321 Idle Speed Control Circuit
1322 Tank Venting Solenoid
1323 Resonance Flaps
1332 Idle Speed Contact
1333 Full Load Contact
1334 A/C Activation
1335 A/C Activation
1500 No Faults Stored
DTC Circuit or description
11 Supply voltage
14 Engine temp sensor 2
16 Throttle potentiometer
17 0il temperature sensor
18 Rpm signal
19 Speed signal -Speedometer
21 Air flow sensor
23 Oxygen regulation
24 Oxygen sensor
26 Ignition timing change
27 Opening winding of idle stabilizer
28 Closing winding of idle stabilizer
29 Activation of AC relay
31 Knock sensor 1
32 Knock sensor 2
33 Control unit faulty
34 Hall signal
35 VarioCam
36 Idle CO potentiometer
41 Control unit faulty
42 Fuel pump relay (DME-relay)
43 Tank ventilation
45 Check Engine warning lamp
51 Injection valve cylinder 1
52 Injection valve cylinder 2
23 Injection valve cylinder 3
54 Injection valve cylinder 4
LH Diagnostic codes
11
Supply voltage
12/15
Idle speed contact
13
Full load contact
14
Engine temperature sensor II
21
Air mass sensor
22
Idle speed control activation
23
Oxygen regulation stop, rich
24
Oxygen regulation stop, lean
25
Oxygen sensor, open circuit
31
Injection circuit shut down
41
Control unit faulty
EZK Diagnostic codes
12
Idle speed contact
13
Full load contact
14
15
Idle or full load contact
21
Load signal LH
26
Transmission protection switch
31
Knock sensor 1
32
Knock sensor 2
33
Control unit faulty (knock sensor)
34
Hall signal
41
Control unit faulty
1996 C4S
