Rear sway bar: Level?
I have H&R adjustable sway bars on my 993 and noticed the rear seems to be sitting slightly off angle from the rest of the car. When sitting under it's own weight (loaded suspension) the center section of the sway bar is not perfectly parallel with the subframe.
Will try to share pics if needed...but curious if anyone else has this issue?
Yes, both sides are connected evenly to the links and the bar is positioned correctly at the pivot points.
Thanks in advance for any insight.
Ahhh. Yes. I forgot the photo I took prior to install.
![](http://i304.photobucket.com/albums/nn184/TomCatAvaTorin/Porsche%20993%20C2S%20Project/PCA004.jpg)
For some reason, I just expected the center section to be level. Once again, thank you Bill for your guidance. You are one of the most valued members here.
