Operation of Vario Ram Induction System
Does anyone know how a mechanical check can be performed to see if the Vario Ram Induction System is functioning correctly on a 1997?
Just turn the car ignition to "on" without starting, the vram flaps should both activate. It will go back to its normal resting position once started, and then move when the appropriate rpm/load is reached.
