will 8.5x18 ET 50 fit a lowered WB?
Looking for track wheels and wondering if these would fit a lowered (near RS height) C2S. From searching I'm guessing the front is pretty close - figured I'd lose 1/4 inch inboard and outboard. Have others used this width and ET?
thanks
front are 8.5x18 et50
rears are 11x18 et40
thanks
thanks
thanks
![](https://forums.pelicanparts.com/uploads20/10_3_11_+0101337040922.jpg)
![](https://forums.pelicanparts.com/uploads20/10_3_11_+0221337040953.jpg)
![](https://forums.pelicanparts.com/uploads20/10_3_11_+0121337041063.jpg)
![](https://forums.pelicanparts.com/uploads20/7_14_11_+0281337041249.jpg)
This is 8.5 ET54 225/40 tires
![](https://forums.pelicanparts.com/uploads20/10_3_11_+0091337040901.jpg)
![](https://forums.pelicanparts.com/uploads20/20111018_WGI_WHO_70721337041159.jpg)
![](https://forums.pelicanparts.com/uploads20/9_19_11_+0061337041198.jpg)
I've also run 9 but there was room for 225/40 tires max
![](https://forums.pelicanparts.com/uploads20/DSC_00011337041445.jpg)
thanks for the input guys and bill thanks for the pictures - amazing. My car is not as low so I think it should be good - I currently have 8" standard offset with 235/40 and no issues with room - also good to know I could go 245/35 up front. There are some used TE37 wheels I'm considering in this size.
thanks again.
thanks again.
thanks again.
thanks again.
the 8.5ET50 is 8.35mm closer to the lip and 4.35mm closer to the chassis
if you use a 245/35 instead of a 235/40 the tire will be 13.35mm closer to the lip and 9.35mm closer to the chassis, that's a lot.
When going to the max tire and wheel sizes the room for differences from optimum goes to zero. That was why I ditched the 9ET50 fronts, they worked fine w/ a 225/40 tires but wouldn't w/ a wider tire, there just wasn't room at the lip. the 8.5ET50 w/ 245/35 is well w/i the envelope of the 9ET50 w/ 225/40 so you should be ok.
thanks again.
thanks again.
Geez, Bill, such blatantly, self-promotional pics of ones car.....
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Love this blue/orange combo! They definitely see you coming!
And as for your knowledge of tires/wheels/offsets/fitment....
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
