removing wheel balance weights
How can I remove the sticky pad the wheel balancing weights were stuck on with? Is Goo gone safe to use on stock wheels?
goo gone will work safetly. I also have success with my pre wax cleaner-I use Colonite Pre Wax Cleaner, and it works great at removing the stuff.
Put a good coat of wax or polish on them when done, helps make the brake/road dust easier to clean.
3M Adhesive Remover works well also. It's what the body shops used to degrease prior to painting. Safe for your wheels. Wax after. I use Rejex on the wheels instead of wax.
