993 Forum 1995-1998
PSS10 or MO30/33 + Bilstein HDs?
Old 05-03-2012, 03:33 PM
MACH993
MACH993's Avatar
Default PSS10 or MO30/33 + Bilstein HDs?
Shockingly, one of my front OEM Monroe shocks sprung a leak after 30K miles. I'm going to replace all 4 shocks. The car's set-up with ROW MO30 or MO33 springs...I haven't yet been able to determine which one. I'd like to maintain more of a street 'softer' ride. Is the PSS10 system flexibility (ride & height) worth the cost (my shop is quoting a $700 diff.) or do I simply go w/the Bilstein HDs w/the current springs? Thanks.
Old 05-03-2012, 03:36 PM
DocTock993
DocTock993's Avatar
I had the same debate for a garage queen - go with the PSS10, you will not regret it!
Old 05-03-2012, 03:37 PM
Falcondrivr
Falcondrivr's Avatar
I have the HD/M030 setup and it's great. But, For $700 more, I'd get PSS10s.
Old 05-03-2012, 04:22 PM
skl2
skl2's Avatar
You will get a million opinions and none are right/wrong. I went with Bilstein HDs/M033 because I wanted height adjustability with a good ride for the street. I dont track the 993 at all. I also did walrod bushing at the same time. It rides 100% better than with the monroes and turn-in is crisp.
Old 05-03-2012, 04:27 PM
CarreraX
CarreraX's Avatar
You may also want to consider the KW V3 coilovers. I have a set and love them. Can be adjusted to a very nice ride if necessary.
Old 05-03-2012, 05:02 PM
MarkD
MarkD's Avatar
the price diff between M030/33+HDs and PSS10s should be quite a bit more than $700... closer to $1K
in any case, if you already have ROW springs, adding HDs would be very cost effective move
That said, PSS10s are a really nice package and offer adjustability (at a price, of course)
As Mark said above, KW V3s are great also. Even more adjustability. Only trouble with KW is availability.
If you have M030 springs then installing HDs might prove to be too harsh, but it really depends on your preference in ride.
It is easy to tell the diffrence between M030 and M033. M030 springs are progressive. The coils will be closer together at one end. M033 springs will be the same coil spacing end to end.
M033+HDs gives a good, all around ride and nice handling performance
Old 05-03-2012, 05:06 PM
RonCT
Moderator
RonCT's Avatar
If you already own the M033 springs, then by all means just get a set of $900 Koni FSDs from one of the sponsors here (my set from Damon / TireRack arrived recently). Many good reviews of the M033 / FSD combination.
Old 05-03-2012, 07:06 PM
Mark Harris
Mark Harris's Avatar
I concur with Mark @ FD's comments regarding costs. I have/had both set ups. I had HD's on my C4S and put PSS on my recent C2S. I don't mind stiff for DD and don't track. Ended up setting my PSS on a firm setting and leaving them which basically is no different that having HD's except for bragging rights.
You will be very happy regardless of which route you take.
Here is a thought. I dropped about another $400-$500 getting the M030 sway set up on my C2S. You already have that so use that savings on going up to PSS.
Old 05-03-2012, 07:24 PM
TheBen
TheBen's Avatar
I went from the Monroes to PSS10's. I also did the Walrod bushings and sways +bushings while I was in there. Very happy with it.
Old 05-03-2012, 08:26 PM
sander97C2
sander97C2's Avatar
Darin sent me the SSK kit, PSS10's and a full set of textar brake pads which should be arriving tomorrow and luckily today I finally received my RS front and rear swaybar kit from Andraya at sunset. I had placed the order September '11 and they just recently got them in stock. From what I've read it is an excellent combination for the street and of course track. I will be doing the big installation this weekend and will check back in with some feedback.
I'm very very confident that my new suspension is going to be great because my oem Monroe's are 67,000 miles old...hahaha, so yea its time for an overhaul
Old 05-04-2012, 10:46 AM
jago
jago's Avatar
you would be the first person i've heard of this year who actually received fsd's.
theyve been sold out forever it seems.
Old 05-04-2012, 02:29 PM
carjmark
carjmark's Avatar
Default Suspenders
I'm going through a similar decision making process on my new to me 95' C4. Noticed that, allthough in euro pricing, http://www.carnewal-europe.com/main.htm has some good info, pictures and attractive pricing on individual pieces and packages (go to suspension, then scroll to P93 for 993). The $700 difference your shop quoted you does sound odd, I'd expect it to be more like $1,200, might be worth checking whether getting charged alot for HD's or getting a great deal on PSS10. Mark
Old 05-04-2012, 03:30 PM
RonCT
Moderator
RonCT's Avatar
Tire Rack has had many 993 sets over the past few months...
Old 05-04-2012, 03:46 PM
MACH993
MACH993's Avatar
Good point. The indy shop gave me the total cost w/installation. I'll certainly ask for the part price breakdown. If you're looking at PSS10s, I found an interesting review on http://www.jackals-forge.com/lotus/993/pss10/pss10.html
Old 05-04-2012, 03:59 PM
tarbender
tarbender's Avatar
You'll also need an alignment after the install. Make sure they have the right equipment to do it properly.
Quick Reply: PSS10 or MO30/33 + Bilstein HDs?
