Where to get an extra DME relay
Before you tuck the extra relay away, confident that you can overcome the ominous and impending sword of Damocles that is the shut down of your vehicle, make sure you test it by using it
I had a brand new one that did not work due to poor soldering on the connections (and it was OEM, not a cheapie!)
Fuel pump relay plus some other functions. Open the fuse box and you can't miss it.
Here is a $10 version at Rock Auto that works great.
http://www.rockauto.com/catalog/x,ca...,parttype,3380
If the original Bosch OEM relay can last 15 or more years, you should expect the next one to have a similar lifespan. The cost difference between the choices therefore isn't a significant factor. Buy the Bosch one. Avoid the URO one at all costs.
