993 Forum 1995-1998
Question for Steve Wiener regarding ethanol
Old 05-02-2012, 01:49 PM
2Many Cars
2Many Cars's Avatar
Don't assume high octane gas contains less/no ethanol. Ethanol actual helps raise the octane rating so it's a cheap way to get higher octane and is frequently used in premium gas blends. There is a common misconception that high octane is better or cleaner gasoline. The octane rating is just a measure of the resistance to detonation, the higher the resistance the less pinging and the more the engine management/boost you can use to get more power. Absent the engine capability and systems to take advantage of the "excess" octane you get no real benefit from higher octane. Ideally you should use the lowest octane possible that your engine systems can take full advantage of, anything more is wasted. If I extrapolate from Steve's numbers then I'd guess any octane over 97 or so is wasted on our NA cars, except perhaps on a very hot day at the track (Steve feel free to correct me if my estimate is wrong).
Besides octane one reason premium gas can still be beneficial is that the refiners often add additional, good additives to premium grades that they don't (or use less of) in lower grades. In so much as those are useful in making your car run cleaner and better it can be beneficial but it won't produce more power. Be sure the premium fuel you're using actually has more good additives than the lower grades or else you're just wasting your money.
Old 05-02-2012, 02:04 PM
os993
os993's Avatar
I just love living in California. 91 octane is the highest we can find (except for special locations selling race gas, but not near me or available for daily consumption), we pay a frickin' premium vs the rest of the country, and we're always getting the "latest and greatest" formulated crap that we have no choice but to buy (MTBE- I think that' what it was called; now we have ethanol to keep the corn growers happy)
Old 05-02-2012, 02:44 PM
Mike in Chi
Mike in Chi's Avatar
Great stuff guys, thanks for all the replies
Originally Posted by il pirata
Go here and zoom in on the map. I think there are three location in Wyoming...not sure which products but most likely 260 GT (100 Octane). Works great at 6000 ft in the summer.
http://www.racegas.com/fuelfinder
Bob that's cool. Thanks. The nearest to me is actually 75 miles away int the sprawling metropolis of Idaho Falls (these things are relative in Wyoming )
I'll check into it.
Originally Posted by Steve Weiner-Rennsport Systems
Hi Mike,
Ethanol at 15% isn't good for our cars: 10% is about the limit before serious degradation of all the elastomers in the fuel delivery system occurs.
I'm just as concerned about this as you are since I live in a "green" state where such environmental measures are deemed good for everyone.
The only things one can do besides seeking fuels without ethanol is the regular use of Marine Stabil fuel treatment and keeping the tank full to prevent condensation from forming. Unleaded race gas is sold in various formulations, some of which contain little or no oxygenates.
Hope this helps,
Thanks Steve. Very helpful as always. I've been using Stabil over the winter storage, will now use it regularly, especially if ethanol levels go over 10%.
also gonna check out availablity near here of ltc's tip about the VP fuels MS93 no eth race gas.
Old 05-03-2012, 05:16 AM
Flying Finn
King of Cool
Flying Finn's Avatar
Hi Mike,
Hope this helps,
I assume the Stabil should be used on every tank?
Also, you might want to check if your local 89 has less Ethanol (this can often be the case).
If it does, you can fill with that and add octane booster to make it 93.
Old 05-03-2012, 09:27 AM
IXLR8
IXLR8's Avatar
In PCA's most recent e-mail newsletter, they had a link to this article regarding 15% ethanol in gasoline and it's long-term impact on our cars' fuel systems.
Lots of talk about fuel grades and additives when the question is, what components specifically are affected by fuel containing ethanol?
As for what fuels contain what, instead of guessing, its best to get that in writing from the fuel company. Shell V-Power up here does not contain any ethanol according to an e-mail received from an engineer at Shell.
Old 05-03-2012, 10:08 AM
porscheralph
porscheralph's Avatar
Try Amazon for the best price on Stabil - I buy it by the case!
Old 05-03-2012, 01:03 PM
TravisB
TravisB's Avatar
I think it would take a lot of booster to bump it up to 93. IIRC, when the bottles say "points" they mean 1 point = .1 octane. So to boost 89 to 93 would actually take several treatments depending on the additive; which would get expensive quickly, and I am sure wouldn't actually work out too well in practice compared to a pump-race blend.
Old 05-03-2012, 01:16 PM
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Specifically? The elastomers in the system; even Viton ones.
Things are different here in the USA due to Federal (Congressional) mandates. With very few exceptions, oxygenated fuels are required by law here for motor vehicles and the current oxygenate is ethanol.
Old 05-03-2012, 02:09 PM
IXLR8
IXLR8's Avatar
OK, so what are the newer Porsches or vehicles in general using now for materials?
According to Porsche, the water-cooled models from the late 90s? are not affected.
Not that it is a pressing issue in my case...yet, but there is no reason why Porsche cannot offer a retrofit package to solve the issue, if there even is one.
Old 05-03-2012, 03:09 PM
Quadcammer
Quadcammer's Avatar
Received 1,448 Likes on 837 Posts
some actually do work, like the lucas product and Torco.
Old 05-03-2012, 03:52 PM
TravisB
TravisB's Avatar
Not bad...would take about a quart of Torco for a full 4 octane bump. At $20ish a bottle, it's nearly a wash there for additive vs. blending $9-10 race gas, but at least you can easily carry around additives. 5 gallons of gas would be more problematic. A more feasible option than I originally thought!
Quick Reply: Question for Steve Wiener regarding ethanol
