Oil Leak...Need ADVICE
I wouldn't crack open the engine until you NEEED a top end rebuild for the valve guides.. and by then you should have 4x the amount of miles on the car (hopefully).. think a lot of advice we get from shops is instantly to re-build.. my last track inspection commented on oil leak coming from the head gasket and to get a top-end.. it was just my chain covers leaking and I need to go thicker oil+tighten the bolts. It also scares a lot of people that top ends are the only $$$ solution.
Keep driving 'em, just keep adding oil
phil.
phil.
In nearly 3 years of 993 ownership, I have yet to see a single drop on my concrete garage floor (other than a spill due to a split filler tube ).
At the end of a driving season, a run of the hand along the bottom split of the engine will dampen my skin...hardly an oil leak.
My car is supposedly original, so I am wondering why my seals don't dry out during winter storage as other owners have had happen.
I haven't yet checked what the method used is for sealing the case halves. Hylomar comes to mind.
OMG!!!! A 911 that is leaking oil?!?!?!
1 quart oil to replenish the supply + cardboard to soak up the drips << $3500 re-seal + part$ + while I'm in there.
But a big +1 on the comment above about storage and seals drying up a bit. Monitor things while you drive her this summer, THEN decide what you want to do.
Blasphemy, but.....put the engine tray back on and it will catch most drips for ya...
My leaks were so bad that oil was coating the back of the car when driven.
Btw, Suncoast no longer matches the price at Sunset. Check both places for the best parts prices...
Exactly. One would have to define what is considered a leak, or at least the severity of the leak.
The SC would leave a drop on the floor now and then.
if it is coating the rear end with oil, then that is worth acting on.
That oil, although not pooling, would work its way along the sides and into the inner jacket of the heat exchangers (sorry no pic), but they were oil coated with grime inside. Little wonder cabin heat smelled of eau de Mobil 1. The innards of the heat exchangers were thoroughly cleaned...issue solved.
Team Owner
Our 993 sat for a few months due to my needing a new knee and unable to use the clutch. It developed a nasty leak - oil on the garage floor, etc. On advice from this group, I ignored it aside from, upon startup, to make sure that the oil level was ok.
After a few drives, the leak stopped and it's remained stopped now that we're back to regular driving. I pass the info on FWIW.
wow...when it rains it Pours. I just noticed that when I turn the AC on, I get cold air from the vent on the left side (drivers side), and hot air from the middle vents and right side (passenger side). Any thoughts?
Hi
Someone told me that they put some cat litter in the undertray to absorb oil. Also when I first got my 993 I had a timing chain cover leak that used to drip onto the heat exchanger and cause a lot of smoke. A bit of tinfoil folded over and made into a "V" shaped gutter directed it away until I had a chance to fix it.
Berni
Berni
So now my indie tells me that if i place the engine tray back on, I could have a fire from the oil burning on the exhaust or heat exchangers or something....I have a hard time believing that. Any thoughts.
Have you tried looking at the oil sending unit thru the fan with a good flashlight for leaks? it normally does that sort of leak when over filling the engine with oil. It also leaks on one of the valves of the vario ram.
The tray is like a diaper but also leaks like a diaper.
