Wheel ET and Spacer Question - NB spec to widebody
I'm considering the purchase of a set of rims for the C2S.
The setup in question has the following (narrow body) specs:
Fronts - 18x8 ET 52 w Bridgestone S-02's - 225/40/18
Rears - 18x10 ET 52 w. S-02's - 285/30/18
I realize that the fronts will be within spec...the rears, as I understand it, require an ET 40 for a factory widebody spec....so it's looking like I'll need spacers.
The question is:
Thanks in advance for the collective wisdom of the board...
Cheers!
The question is:
- Am I correct in assuming I'll need a spacer in the neighborhood of around 12mm or so? How much latitude do I have on the spacer depth? I don't want to push the wheel 'right to the edge' however, I would like to get a decent stance with filling the wheel well out reasonably
- With the spacer...will I require updated (longer) studs
- Anyone done something with similar specs and what did they go with in terms of hardware?
Cheers!
