993 Forum 1995-1998
Intake trumpet removal - Broken intake bolts!
Old 02-25-2014, 07:31 PM
  #31
L23FPorsche
L23FPorsche's Avatar
Originally Posted by Kmassed002
My issues were completely resolved on this one and the threads were able to be saved without a helicoil. I think it really takes patience and a good tap and you should be fine. I would recommend you fill that intake port though.
I have a good tap, but not sure how that would help without the remnants of the bolt being removed? The port is filled and I'm running the shop vac near the repair.
Old 02-26-2014, 09:24 PM
  #32
KMASS993
KMASS993's Avatar
I drilled mine out till just the threads were left... Then used the tap of the same size to clear them out.
Quick Reply: Intake trumpet removal - Broken intake bolts!
