Cracked spoke on my FM-10
I recently bought a set of FM-10s used and after getting new tires on them, I was giving them a thorough cleaning and discovered a crack on one of the spokes (see photo below) that I did not see prior to this. Called Alan at Fikse, who was helpful, and I'm getting set up to replace the center (for $425) in a few weeks, hopefully.
My question is, how common is this? I'd be interested to hear from others who have experienced or seen similar failures.
Thanks,
Rob
Thanks,
Rob
![Name: IMG_1374.JPG
Size: 652.4 KB](https://rennlist.com/forums/attachments/993-forum/624008d1334440463-cracked-spoke-on-my-fm-10-img_1374.jpg)
Under the original ownership, Fikse were top quality race wheels for many years. But I heard of cracks and customer service issues towards the end, around the time that original company was going under.
I am sure the new owners will make things right - and it sounds like they are doing so for you.
Keep in mind these are really track wheels, and like any of the others (BBS Motorports, Forgeline, CCW, Jongblood, etc.) they do require regular inspection as they all may eventually crack under hard track use (or punishment on the street).
But they're good, strong wheels - no doubt.
Best,
Matt
Whether the failure was a quality issue
Best,
Matt
RL Technical Advisor
Rob,
Fikse makes excellent wheels, however none of them last forever when subjected to heavy track use on DOT-spec tires or slicks. This isn't uncommon at all and all part of buying & owning such things, regardless of manufacturer.
One thing I always recommend before buying used modular race wheels is having them Zylow'ed to see if any cracks are present. This procedure doesn't cost much and the results should be factored into the price.
Agree that they are excellent wheels; I just wanted to see how common/uncommon this was.
This wheel was made Feb 2001, according to manufacturer, so well before they "reorganized".
Thanks for the tip Steve. Not familiar with this process but will look into it. Is this something I could find on the dry side of the Cascades, or is it typically only available in urban centers like Portlandia or Pugetropolis?
There are folks who do this in Seattle, Portland, and I'm sure, Spokane. You should see who provides "Non-destructive testing" in your area. Zyglow is whats used to crack-test non-ferrous metals, as Magnaflux is used for ferrous ones.
With the amount of curb hopping we do, I'm shocked wheels hold up as well as they do.
Who remembers those old, non-drop center BBS modulars? Either they were the worst, or I had a couple of customers who were unlucky.
He has had one (or more) center(s) replaced and the replacement has since cracked again.
He spoke to the company which is under new management and was told he is out of luck.
Ten years ago, Fikse built a good part of their reputation for taking care of cracked wheels, even if they had seen track usage. That incredible commitment to customer service was one of the main reasons I chose to run their wheels and boost them whenever a thread on wheels popped up on the 993 board or the racing board.
A coworker has Fikse wheels that he bought from Fikse for his 330 Ci shortly after he bought the car new. They do not see any track use.
Quality control / design problems happen and if his center that cracked the first time is due to that, that might be accepted...things happen...so fix the problem and it shouldn't happen to the replacement he was given. But it has.
Considering that his wheels aren't abused, if this was a production wheel that was offered on a manufacturer's vehicle, the NHSTA would likely issue a recall.
He loves his wheels (so do I; they are absolutely gorgeous) and the top notch service he received in the past (he boasts about it), but he would not buy another set from them at this point.
I wouldn't think twice about another pair of Fikses.
Alan has gone the extra mile for me twice and I appreciate everything he has done. My wheels are exclusively tracked and have held up well.
Poor Alex just can't seem to find a single source or product which meets his over exacting expectations.
I have a lot of things that meet my expectations, those that don't, I don't buy.
Quite right. That's why Porsche has not offered a light, forged wheel since 1989. Production of truly lightweight forged wheels has been passed along to the aftermarket for the most part.
Lightweight forged wheels are very strong - to a point. Most are designed for smooth tarmac or for "track only", and can work great if you have a thorough inspection regimen.
There is a cost to saving 2, 3, 4 or 5 pounds of unsprung weight per corner. Tough to build an extremely light wheel that will be more durable than a much heavier comparative.
Consider, if you badly bend or crack a cast wheel, you discard it and move on. A modular forged wheel can be refurbished - a $400 Fikse center is not a bad deal, really. On that basis, replacing bent rim halves should only be a few hundred dollars. At least they are serviceable. Same reason I chose BBS Motorports wheels...
Best,
Matt
You should also check with rennlister 'thatcher' he has a bunch of wheel parts including centers for very reasonable prices. I paid way less than $400 for a fikse center I needed a little while back.
