Failed smog, question about jectron
My car just failed smog with slightly high hydrocarbon, I think I may be partly responsible because I have not driven much for a few months and only allowed 15-20 to heat up, but I want to get serious about passing now. I am replacing my plugs and wires, fuel filter (fix the leaking valve covers while I am in there) and I am thinking of adding Jectron and ventil saber (?) My question is I just had the oil changed a couple of months and 100-200 miles ago, I really don't want to do it again so soon, do I have to change my oil again after adding the treatment? If so can I just change the oil and not the filters? What problems does not changing the oil cause?
Anthony
Anthony
RL Technical Advisor
No worries,....just add a can of each LubroMoly product and go drive the car pretty briskly for a few hours. Change the oil in 3K and you'll be fine.
ALWAYS replace oil filters when changing oil.
