RoW Height pics
I have a chance to get a set of the M029 springs pretty cheap, but can't seem to find any pics of cars with the Standard RoW ride height (20mm drop front, 10mm drop rear from US SUV height). Most of the pics I've found have the M033 or M030 springs which are lower (30mm drop) then RoW. Does anyone here have pics using the M029 springs or have a Euro spec car with the stock suspension? I'm using Koni FSD's so the spring will determine ride height.
Standard Euro spec non-sport suspension with stock monroe's and stock springs. 50K miles.
Full tank, but cold weather. I notice at least 10mm lower ride with warmer temperatures!
Not quite the right angle but maybe good enough for a reference!
H&R street kit coil overs with RoW height adjustment. I didn't want the car any lower than this.
It's easier to work with the floor jack and drive-ability doesn't suffer.
Ed
Ed
![](http://i1011.photobucket.com/albums/af236/EckFe1/993frontview.jpg)
ah cool. Very subtle difference, I was hoping it would have been more, but anything lower is better. I'm surprised how much lower the RoW Sport (30mm drop) looks even though it's only about 1cm lower front and back. Frankly, RoW standard seems closer to USA spec then it does to Row Sport.
