For those with coupe, DAS Rollbar, and racing shells...
If your front seats don't tilt forward, can you still install the DAS coupe rollbar without removing the front seats? I get you still have to remove the rear seat backs.
Agent Orange
I removed one of my seats to fit the roll bar in the RSA. It's very easy to do, just unbolt the seat from the rails and move it forward. But be careful with the allen bolts since they are made of cheese.
I haven't installed the setup yet. Well, frankly I don't even have the car yet. But I do have the rollbar. Go figure.
I install/uninstall the bar about 5-7x per year in my cab, which is relatively painless now that I have all the tools (impact drill for speedy disassembly, and come along strap for installation). Trying to figure out any challenges ahead of time with a coupe...
It's going to be almost impossible, if not 100% impossible, to install the bar if your seats don't recline. As ilko said, taking the seats out is super-easy. Even if your seats did fold forward, the bar is so heavy and awkward that it would be really easy to ding/puncture/scratch your seats. Moreover, removing one seat (or both) gives you so much more room to maneuver. If the bar and chassis holes don't line up properly, you'll be using a bottle jack to stretch the bars or ratcheting straps to pull the bars together.
Thx guys. I was going from the experience of removing stock seats, which is sort of a PITA getting the allen wrench in the tight spaces. Shells are easier then? (Or stick with reclining).
Agent Orange
1) The cab & coupe roll bars are different height AFAIK.
2) The bolts and nuts are supposed to be a one-time application according to the guys at CDOC.
Regarding the removing the allen head seat bolts, just be sure to use a dedicated allen head socket for your ratchet. I think people have issues if they have to insert, remove and reinsert the allen key over and over again. With a ratchet, once it's in, there's no need to pull it out and potentially round out the allen head.
#1 on the earlier comments. The DAS install is much easier if you remove the front seats.
My shells are much easier (lighter) than the stock seats. Neither are that hard though. I use a wobble extension.
I also started out planning on R&Ring the bar for events, it was too much work though. I did it once or twice and then just left it in.
One suggestion I would offer is to bend the bar to properly fit your car. I have installed a couple of these and the fit varied. The DAS bar seems to be made from malleable steel so I was able to bend it to the shape I needed to correctly fit my car and the bolts just thread in by hand. If it doesn't fit properly, it is a wrestling match to install it.
Pete
Pete
Beats having it be too brittle and cracking. Trust the board and DAS; the bar works as intended. Not only does it meet the standards for PCA racing (for rookie candidates and only good for two event weekends), but it also has been proven in real world track roll overs.
Agent Orange
The DAS roll bar is very slightly flexible, yes. I've installed 3 of those and 2 fit in without issues, the third had to be muscled into place and I'm talking about squeezing it maybe 4mm so that the holes align and the bolt can go through. I don't know if the bar was bent or the car I installed it was bent (a friend's 964) but it was a pain to install and had it not been a little flexible it would've been impossible to fit it in.
