Rear toe control arm, seriously?
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
![](https://lh5.googleusercontent.com/-GGDJXwDVJgU/TzvnvPkcWwI/AAAAAAAAEaA/8A-ygY2gG_I/s581/IMG_20120215_191303.jpg)
Do I really have to drop the crossmember in order to change the control arm?
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
King of Cool
Terve Jakko,
Just take them out, it's not a big deal.
I assume you mean the headers part, and not the heat tubes that go from the headers (which wod be even easier).
I'm actually doing the same (will put all monoball links) in a bit although I assume I'll have easier time since I have custom headers.
no need to remove or dent anything.. i just did this to install my PSS10s.. lift the engine a bit (just use a jack and it will move 1 cm) and make sure the bolt is all the way to the side.. will pop right out. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
phil.
phil.
King of Cool
you might need to add a bit of a wiggle (proper german wiggle) to get out. I scratched my head at first as well, but then always think that there was some way engineered into the design. AKA - never force \ dent \ damage anything.. there's usually another way.
phil.
phil.
Jaakko,
Stop being a whiner and pull off the heat exchangers. Then you can give them a proper cleaning and have the shiniest ones on RL !! Just thinking.....
'tis the way! Also, if you back off the two 13mm nuts on the motor mounts, more clearance can be had if absolutely needed: just watch the intake manifold & exhaust tips as a guide against going too far ... and have the engine well supported. No need to remove the bolts .... just loosen.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If your motor mounts are sagging, jacking up on the engine will help you. Also, rotating the bolt for best clearance often times is also a must.
I'm replacing mine as well right now - '95 with 130k miles on it.
My heat exchangers have this signature "dimple", most likely done by my previous mechanic who installed my PSS9's. The current shop doing my alignment pointed this dimple out to me and told me his shop would never do this.
I am going with Porsche factory rear toe control arms bty....
I am interested in the used ones if anyone wants to sell. Will pay $50 per pair, thnx
BTY, just curious, what are you going to do with them? Mine are shot (the ball socket side with the bolt attached to it).
pm sent,
still interested for more,
thank you
thank you
