993 Forum 1995-1998
Door hardware tune-up
Old Feb 11, 2012 | 11:32 PM
Christian J's Avatar
Christian J
Default Door hardware tune-up
Im in the middle of an exterior detailing project and my door handles had to come off. While I have the interior door panels off I decided to replace the speakers and add some dynamat...
I figure that I may as well replace the actuators and clean up whatever I can to ensure that everything works smoothly. Andreas is known to have silky smooth door handle action. Any tips on cleaning the guts?
Old Feb 12, 2012 | 09:28 AM
AOW162435's Avatar
AOW162435
Seared
Now where on Earth did that little tidbit come from? 'Tis true.
I've never messed with anything inside of the doors, so my only thought would be to study the operation of the linkages and then properly clean & lubricate all pivot/contact points.
More pics of your amazing find are always appreciated.
Andreas
Old Feb 12, 2012 | 01:41 PM
600RR's Avatar
600RR
FWIW: While you have the panels off install Window Express. One of my favorite mods.
http://www.paragon-products.com/Wind...dowexpress.htm
Old Feb 12, 2012 | 02:56 PM
JPP's Avatar
JPP
and check the pins on the lock actuators .. they can shear off from use so good time to inspect and replace with factory plastic or create your own bullet proof ones out of metal ...
Old Feb 12, 2012 | 03:08 PM
vincer77's Avatar
vincer77
While your at it...
Old Feb 12, 2012 | 03:49 PM
mike cap's Avatar
mike cap
Christian,
I may be the only RLister that has done this DIY except for the originator. But if you are in there it is pretty straighforward. It's the door strap detent mod that 'may' prevent the dreaded broken weld syndrome.
http://p-car.com/diy/doorcheck/
Unrelated, you own two TR6's?? Unfair! I think those more fortunate than others should share..... the transport company will be by next week. They are my second favorite British car ('67 E-Jag is # 1 of course) and are a sweet looking car. Post some pics if you can.
Old Feb 12, 2012 | 04:06 PM
Blue TTop's Avatar
Blue TTop
I recently took my door handles off for a good cleaning and to replace the gaskets. Gaskets were cheap and well worth the effort. Overall easy job.
Gaskets were cracked and broken:
This area was never cleaned before:
Cleaned, polished, and waxed:
Old Feb 12, 2012 | 04:50 PM
NP993's Avatar
NP993
Curious to see pics of the inside of the door -- I've never had the panels off but plan on doing so soon. The passenger's side door doesn't click closed like it should, and it's not the hinges or striker that seem to be the problem. Probably just needs to be cleaned and lubed after all these years. I plan on replacing any wear items inside the mechanism & linkages. Anyone ever done this?
Old Feb 12, 2012 | 05:16 PM
nile13's Avatar
nile13
Andreas' door handles are, indeed, silky smooth. When my car was in his garage last May we thought about it and sprayed liberal amounts of WD40 (or similar substance) into the "trigger' behind the door handle and into the lock on the door jamb.
The improvement was immediate and, honestly, astonishing. It become an absolute pleasure to open the doors. As we did them one at a time I actually went around the car side to side and compared.
Old Feb 12, 2012 | 05:34 PM
Blue TTop's Avatar
Blue TTop
A few pictures from when I had mine apart.
Door handle still in place. Held by 2 nuts (one shown):
Door Handle removed:
Old Feb 12, 2012 | 05:37 PM
NP993's Avatar
NP993
Thanks....looks like a job for HHS-2000
Amazon Amazon
Old Feb 12, 2012 | 07:34 PM
Meatball964's Avatar
Meatball964
Not to side track too much, but what is the desired lube for door hinge/hood/engine lid etc.....WD40 ? White lithium grease ? Or something else.....
Old Feb 12, 2012 | 07:44 PM
nile13's Avatar
nile13
WD40 is not really a lube. I'd say white lithium would work well.
Old Feb 12, 2012 | 09:13 PM
ble2011's Avatar
ble2011
Never use WD40 for a long term lube. It's designed primarily as a water displacement product. An all weather white lithium spray grease would be my choice. In fact, I have new door handle seals waiting in my basement and I plan on doing this same job in the spring.
Old Feb 12, 2012 | 10:29 PM
Christian J
Those pictures are great. Let's see,
-yes to white lithium grease on the hinges
-my door checks are tight, quiet and a-o-k
-I bought one tr6 when I was 15. After 25 years of low budget maintenance I got a do-over by buying a mint one on BaT
-Ordering new actuators Monday
-The handles are now cleaned of gunk. There was some old grease that had just gummed up so nothing was all that smooth and the pins wouldn't retract quickly. I'm inclined to use fluid film on the moving parts now but they're not going back in for at least a week so I have time to think about it.
-definitely looking into that one touch window mod
