speaking of brake rotors....
after replacing the front rotors, I went out for some light bedding and noticed the initial wear pattern showed the pads polishing only the inner and outer edges of the rotor. I didn't change the pads because it wasn't necessary. Any thoughts on the initial wear pattern? I expect the pads will become better bedded (mo' bedder?) with more frequent and aggressive braking, but I'm curious if anyone has noticed this as well.
Marc
Marc
I found that after all the mucking around it was easier to just use OEM parts.
Maybe it's different for you guys with all the choices you have though.
I installed new pads as well just to make sure everything was sweet.
Brakes matter!
Brakes matter!
this is normal...and I have been told you should bed in new rotors with old pads...or vice versa...but not do both at the same time.
I use OEM rotors and pads. Probably should have done something to the pads, but didn't take the time. I know the pads will eventually get fully bedded, just curious if anyone else had noticed a similar wear pattern. no worries here.
thx
Marc
thx
Marc
