993 Forum 1995-1998
Hot start...probs
Old Feb 4, 2012 | 11:29 AM
fuch's Avatar
fuch
Default Hot start...probs
I have a no v/r 993 and if I go out for a 1-2 hr drive and then turn off she doesn't want to start again, cranks over fine, cold start fine.... Leave it for 2 hrs and bingo!!...she's alive
New dme check!!
Crank position sensor???
Flux capasitor check!!
What do you think guys???
Thanks fuch
Old Feb 4, 2012 | 02:14 PM
EckFe1's Avatar
EckFe1
Leaky fuel injector, maybe more then 1.
Old Feb 4, 2012 | 03:22 PM
fuch's Avatar
fuch
Ok great will check them out........anything else?
Old Feb 4, 2012 | 08:29 PM
Basal Skull's Avatar
Basal Skull
Was going to answer on the other thread .... Sounds like a typical fuel pump check valve problem
Old Feb 5, 2012 | 09:48 PM
shadow993's Avatar
shadow993
Head temp sensor! I would put $$$ on it.
I believe it has 4 temp readings and one can go bad. Mine was on a warm restart as well.
Old Feb 6, 2012 | 12:46 PM
fuch's Avatar
fuch
Thumbs up
I got a feeling its the cyl head temp sensor to....thanks
Old Mar 17, 2012 | 07:55 PM
fuch's Avatar
fuch
Thought I would give a update.... Crank position sensor!!
But next time I'm up on the ramp I'm gonna change the cyl head temp sensor to....
Old Mar 17, 2012 | 09:03 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Crank position sensors are becoming a little more problematic as these cars get older.
These two sit together and are subject to heat soak, hence the intermittent behavior.
I'm in the camp of wholesale sensor replacement on some of these when these cars accumulate higher mileage or live in hot climates. Sure beats walking, or even the aggravation of waiting for the tow truck (and all that entails).
Old Apr 18, 2012 | 09:35 PM
jo-hans's Avatar
jo-hans
Can someone confirm these are the parts to order to replace the CP sensor?
996-606-105-00 Sensor
999-652-916-40 plug socket
999-652-871-22 Connector
999-704-161-40 gasket
