muffler tip rattle
Kevin, yes, the tips are the same with Bischoff and Gillet
The outlet on the muffler is the difference
Either tip will fit your setup
check for contact between the tip flange-shield-thingy and the cat shield or bumper cover
Take tip in hand - drop on floor ... if there is a tab/heat shield/etc loose, you can tell by the sound.
If so, tap it with a hammer/cold chisel/screw driver .... to find where it vibrates ...
Have a chum MIG a spot of weld of said point ...
If you have neither chums, nor favours to collect, a deft strike with a ball pein hammer may sufficiently reshape the metal to take the resonance vibration frequency beyond your range of hearing ...
Reinstall tip & drive on: no, it's not perfect - but it wasn't concours to start with ...
On to next problem - there is always another waiting ...
