993 Forum 1995-1998
High pitched whine from engine bay
Old 01-07-2012, 02:52 PM
ETW
ETW's Avatar
Default High pitched whine from engine bay
Anyone else have this? Just started last week. Will whine for a minute then go away for a few minutes. Gets higher pitched with more RPM. Happens hot or cold. Best way to describe it would be that it sounds like a really high pitched twin screw supercharger or like the tranny in a cup car. Everytime I get to listen to it it goes away but I think it's coming from the fan area. Any tips would be appreciated
Old 01-07-2012, 03:16 PM
AOW162435
Seared
AOW162435's Avatar
With the engine off, tie the belt-sensor roller back so that it no longer touches the belt. Start the engine. Did the noise stop? If so, the bearing within the roller is shot.
Other possibilities include the fan hub bearing, and the bearings within the alternator.
Andreas
Old 01-07-2012, 06:34 PM
Garth S
Garth S's Avatar
The SAI pump can also make disturbing noises if it is approaching bearing death ..... but only for a min or so after start up.
Old 01-07-2012, 07:25 PM
shadow993
shadow993's Avatar
Old glazed belts or as the previous said, belt sensor.
Old 01-07-2012, 10:56 PM
Magdaddy
Magdaddy's Avatar
interesting...mine makes almost a whistle noise, albiet high pitched. Only at start up, and seems only when it is cold/wet outside, but not everytime.
It goes away after a few minute's. I initially thought it was originating somewhere around the blower/airbox, but seems more toward the fan/alternator area now.
Winter time fix maybe.
Old 01-07-2012, 11:58 PM
ETW
ETW's Avatar
Andreas
Thank you!!!
That's exactly what it was. Removed the whole sensor and the noise went away. The bearing is toast- all rusted. I tried putting some grease in it then re installing but it made no difference. Just ordered a new sensor
Old 01-08-2012, 09:23 AM
AOW162435
Seared
AOW162435's Avatar
Originally Posted by ETW
Thank you!!!
Excellent.
Andreas
Old 01-08-2012, 10:20 AM
DanL993
button queen
DanL993's Avatar
Andreas ROCKS!! (Seriously--he's pretty good.)
Old 01-08-2012, 06:24 PM
e9stibi
e9stibi's Avatar
Those sensors fail quite often considering the age of our cars.
Old 01-08-2012, 06:41 PM
AOW162435
Seared
AOW162435's Avatar
And the fact that the bearings are not sealed.
Andreas
Old 01-08-2012, 07:24 PM
porscheralph
porscheralph's Avatar
Had the same issue with mine - just removed it and did not replace - I figure I gained more then 10 hp due lack of friction.
Old 01-08-2012, 07:57 PM
AOW162435
Seared
AOW162435's Avatar
Actually, I think you gain around 20 hp.
Did you terminate/loop the sensor wire to keep the light off?
Andreas
Old 01-08-2012, 10:00 PM
e9stibi
e9stibi's Avatar
You are brave. I consider this one of the more essential alarms. Not like the brake pad sensors ...
e9stibi
e9stibi's Avatar
You are brave. I consider this one of the more essential alarms: Time critical to respond to and potential high consequence. Not like the brake pad sensors ...
Old 01-08-2012, 10:14 PM
porscheralph
Not sure what you mean - if the belt breaks you will know it right away.
Quick Reply: High pitched whine from engine bay
