993 Forum 1995-1998
Drive cycle with cat deletes
Old Mar 6, 2014 | 12:26 PM
chaoscreature's Avatar
chaoscreature
The first set of O2 sensors are there for engine tuning, the 2nd set make sure the emissions systems are working properly. The ECU compares the voltage readings against an internal database of normal values. When you place the post cat sensors in the engine bay the O2 sensor will read WAY too much oxygen and will throw a code.
